Elements Beta 18 (build 23018)
Hello again,
Hot on the heels of yesterday’s HUGE Beta 17 release, we have B18 — Lots of great little fixes in this one, and plenty more to come next week!
What’s New in Elements Beta 18?
  • Fixed a crash that occurs while filtering any of the outline views in the the sidebar!
  • Typography Classes can now be duplicated via the right-click menu.
  • Typography Classes editor now remembers the last selection (instead of always revering to H1).
  • Menu: Added custom dropzone for hamburger
  • Menu: Added option to set colour for hamburger
  • Menu: Added site link and fallback link for logo
  • Typography: Fixed issue with using bold and colour on text
  • Typography: Fixed issue with empty P tags not being displayed in preview
  • Button: Hover controls consolidated.
  • Text: Links can now be styled!
  • Container: Background is now transparent by default
  • Numerous other fixes and enhancements
Get the Update
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time, however you should sign-up up here to be notified as more places become available.
On the @richtext > Block Style > Type, could you please add a none option, so when this is used in a custom element, it doesn’t create tags as other tags will be needed that wrap the text.
