Elements Beta 19 (build 23021)
A third beta in as many days, how exciting! This quick Friday morning build fixes up a couple of pesky Typography issues, things should none be running a little smoother now.
What’s New in Beta 19?
  • Typography style dropdown now selects “none” by default
  • Fixed another P class spacing issue in the Typography Component
Get the Update
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time, however you should sign-up up here to be notified as more places become available.
