Hello again,
Today’s beta is a whopper! We’ve mainly been focusing on fixing bugs these past few days, but we did also managed to squeeze in a fancy new colour feature into the Theme Studio…
What’s New in Beta 21?
- Added support for custom colour strips in Theme Studio!
- Overriding colors in the Theme Studio now removes them from the drop down in the editor
- Colour Chooser now has search focus in Theme Studio
- Added support for selecting “No Colour” in the Theme Colour picker
- Copy and pasting components now maintains images
- Remote resources now render correctly when previewing
- Global Overrides now work with Typography
- Fixe an editor rendering issue when using flowing column selection
- Fixed an editor rendering issue with using float left for image in CSSS
- Fixed a crash when undoing a change in the Custom Classes area in Text Components
- Fixed some more issues with the Resources Editor (still more work to be done here…)
- Improved font resource handling in the Theme Studio
- Disabled Quick Look generation as it was causing saving issues (will fix later)
- Further improvements to Gallery Component (Still a work-in-progress, use with caution)
- Menu: Fixed erroneous settings under Logo
- Button: Font weight can now be set
- Button: Hover on parent now works
- SVG: Fill and Stroke Colours now support opacity
- SVG: Stroke can now be animated
Get the Update
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time, however you should sign-up up here to be notified as more places become available.
