Hello,
Today’s beta introduces the ability to create and add Element Dev Packs, plus a whole host of other fixes.
Be sure to watch Dev Diary Ep51 to learn more about what’s new.
What’s New in Beta 23?
- New Addons tab in the Settings window
- Ability to create Element Dev Packs
- Ability to create Components inside of a Dev Pack.
- Improved rendering performance
- Global overrides only shows when necessary
- Improved sync when a component title changes
- Fix a bug preventing grid overlay working
- Fixed crash on macOS 13/14 when opening theme studio
- Improved editor component highlighter
- Custom shadow control now functions correctly when dragging
- Fixed links with no anchor appending a
# - Fixed font change forcing editor to reload and cause flashing in editor
- Fixed missing icons on macOS 13/14
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
