Elements Beta 29 (build 23171)
Hello again,
We’re working on some big things, but they are not quite ready to include, so this is a little interim beta to keep things ticking along nicely.
What’s New in Beta 29 (Build 23171)
  • Added basic Lightbox support to the Image Component
  • Added further support for Conditional Includes to the Elements Language
  • Improved Gallery Component
  • Fixed issue with Anchors not working in Typography blocks
  • Added third level menu support to Standard Navigation
  • Added an option to hide text in Button Component
  • Fixed display error in Image Component
  • Fixed display error when removing Gallery resources
  • No longer resize images when not required in Image Component
  • Fixed an issue with FileWrappers in macOS 15
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
