Elements Beta 32 (Build 23189)
Hello,
Just a small Monday update to kick the week off. This build should fix the spinning beach-ball issue caused by the new Workspaces UI.
We’ll have another beta out later in the week with some more pressing fixes. Stay tuned!
What’s New in Elements Beta 32 (23189)?
  • Improved stability of the Workspace UI feature
  • Sidebars remember state correctly on launch
  • Fixed an Issue where the Component Inspector would fail to update
Join the Private Beta
Post a comment below requesting access and we’ll send you the details via the email address attached to your forum account.
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
