Elements Beta 36 (Build 23254)
Hello again,
As promised, the new RapidWeaver Elements beta is now available along with the demo files from this weeks Dev Diaries — Be sure to watch Ep63 from Today to learn more about the beta!
Project Downloads
What’s New in Elements Beta 36 (Build 23254)?
  • Fixed issue with being able to deselect all pages
  • Auto Refresh Preview in Browser option added to Preferences
  • Quick Find Menu updated to include Components (Command-Shift-F)
  • Multiple Undo Improvements!
  • New Accordion Component
  • New Filter Component
  • New Filter Tags Component
  • Dev Components can now use Collections
  • Added support for Collections in the Inspector
  • Improved handling when moving or remove multiple components
  • Various UI tweaks!
Known Issues
We’re aware of some issues effecting text styling, these will be fixed in a future build once we’ve upgraded to Tailwind V4.
Join the Private Beta
Post a comment below requesting access and we’ll send you the details via the email address attached to your forum account.
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
I request the Elements beta for testing. Thanks.
No problem, check your email for details :blush:
Could i have access to the beta project please. Does that also run along side 0.97 or do i need to uninstall that?
Thanks.
Hi @Cablecar69, 0.97 is the latest build :+1:
We’ll have a new build of Elements with Templates and Resources going out this week, keep an eye out for that!
