Elements Beta and form problems (SOLVED)
I have now been in dialogue with one.com regarding issues with sending forms from my website. You believed that the problem was on their end.
The issue has been reviewed by their 3rd level team, and they provided the following feedback:
"A review of the logs shows that the form is not sending any request to the mail server at all. This means that the error occurs before the script attempts to connect to the SMTP server.
This may indicate that the issue is at the PHP level, or that the form is not properly set up/configured."
I need assistance with this.
I use one.com without any problems touchwood
Are you using Elements Beta?
yep
Strange :thinking:
what security settings you using
mine is send.one.com
I will try that setup.
I have 3 forms working with that setting
It didn’t work for me :thinking:
is your from address and to address should both be your address
no reply is not YOUR email address surely
no-replay@ is a real email address (username).
no-replay or should it be no re-reply
no-replay@… I use the same one in Elements Classic, and it works fine.
I had that trouble when forms first come out but as I say all works ok now….try rebooting as youve changed the smtp server now,i also deleted everything from the server occasionally and upload all files
also have you got another email address you can try
im assuming you have the error and success component bits in you form
I have now deleted everything on the web server and uploaded everything again. I still have the same problem.
guess you will have to wait fro elements team to get back
