I have never been able to get the passkey to work and always used Password to get to the online admin page. Tonight it suddenly just shows a page saying Elements CMS and a blank box underneath that you cannot enter anything into!
Anyone else getting this issue? What might be the cause?
The Online Editor login page on my site ( Admin ) is loading a blank form — the “Elements CMS” heading renders, but the login box itself never appears, in every browser I’ve tried (DuckDuckGo browser, and confirmed independently in another browser too).
The browser console shows this error on load, coming from your own bundle:
Uncaught (in promise) InvalidCharacterError: Failed to execute 'setAttribute' on 'Element':
'...ding-none mb-2for' is not a valid attribute name.
at online-editor/vendor/preact.module.js?v=20260538:2:1814
along with two additional uncaught SyntaxErrors (“Invalid left-hand side expression in postfix operation”) right before it. It looks like a malformed class string got concatenated with a for attribute somewhere in the login component, which throws and stops the form from rendering at all.
This happens on a hard, cache-busted reload too, so it doesn’t seem to be a caching or browser-extension issue on my end — looks like a bad deploy on build v=20260538.
Could you take a look? I’m currently locked out of the admin entirely since there’s no other login path for this site.
Pretty sure it’s the same bug… Claude Found it and fixed mine - told me not to publish or it might re - write our correction…
Cause: editor/vendor/tiptap-bundle.module.js is not valid JavaScript. At character offset 92,096 it emits ProseMirror’s createKeyas:
function tc(t){return t in jo?t+"$"+++jo[t]:(jo[t]=0,t+"$")}
The source is name + "$" + ++keys[name], but the minifier dropped the space, so +++ parses as a postfix ++ applied to the string literal "$". The entire bundle throws SyntaxError: Invalid left-hand side expression in postfix operation in both Safari and Chrome, Tiptap never initializes, and the body pane stays empty.
For me - Claude fixed the tiptap bundle and a index.html file…
The fix: and why the index.html had to be updated
Inserting one space (+"$"+ ++jo[t]) makes the bundle parse; await import('tiptap') then returns Editor, Image, Markdown, StarterKitand the editor works normally.
Note for the fix: the import map in the published dashboard page pins modules with ?v=20260566, and Apache serves them with Cache-Control: max-age=2592000. Shipping a corrected bundle under the same version stamp won’t reach anyone who already loaded the broken one — browsers won’t re-request for 30 days.
The version stamp needs to increment alongside the fix.
this didn’t work fully for me, with Claude’s help I had to modify 1 more file that fixed it.
The fix is simple: in /rw/elements/com.elementsplatform.cms/editor/app/pages/Login.js, there are 5 occurrences of the exact text mb-2"for=" — each needs one space inserted to become mb-2" for=".
Michael, you seem very knowledgeable about this stuff, nothing to do with this thread but did you see this thread of mine that has had no answers? Can you assist?
That menu problem looks like a classic CSS issue. But I’m weak on CSS and like Michael, would lean on Claude. Something about layer targeting and CSS and JS not agreeing, I think. The best solution in these cases is indeed @dan but he’ll want to see your project so he can see how the Components are used.
Thanks everyone who dug into this, the console errors and the Login.js / tiptap findings were a big help figuring out where the problem was.
I’ve got a fix in place for the next build of Elements. It was re-minifying files that were already minified during publish, which mangled the online-editor assets. That’s corrected now
Once you get the new build, republish so the fixed assets are applied.
