Elements CMS works locally but not on Synology Web Station (only first components visible)
Description:
Hi everyone,
I’m using Elements by Realmac with the new CMS component.
Locally everything works perfectly, all CMS elements are displayed as expected.
However, once I deploy the project to my Synology NAS (Web Station, DSM 7, PHP 8.2), only the first static components show up. All CMS-driven content remains empty.
What I’ve already checked:
  • Running PHP 8.2 (assigned via Web Station profile)
  • mbstring extension is active (phpinfo() confirms → mbstring support enabled)
  • All CMS pages are exported as .php (not .html)
  • Full folder structure uploaded (cms/, cms-data/, rw_common/, resources/)
  • cms-data folder has proper write permissions for the webserver user
  • Virtual Host points to the export folder, index.php is set as index file
  • info.php test shows PHP 8.2 is working and mbstring is loaded
Question to the community:
Has anyone successfully run Elements CMS on Synology Web Station?
Could I be missing another PHP extension (like pdo_sqlite, json, …) or a specific Apache/Nginx setting (rewrite/module) required for the CMS?
Or does Elements CMS need a particular adjustment to run smoothly on Synology?
Thanks a lot in advance for any advice! :folded_hands:
Patrik
I haven’t got a Synology device.
That said, does the PHP log on you Synology device shows anything when you access the web page with your CMS entries?
I fixed the issue :white_check_mark:
It wasn’t PHP or missing extensions – the problem was simply file permissions on Synology. Elements CMS (Monolog) couldn’t write to app.log inside the logs folder.
Fix:
Give the Synology webserver user (http) ownership and write access to the logs folder:
sudo chown -R http:http /volume1/web/fdpkandidaten/rw/elements/com.realmac.corepack/api/logs \
&& sudo chmod -R 775 /volume1/web/fdpkandidaten/rw/elements/com.realmac.corepack/api/logs
After this change, Elements CMS runs perfectly on Web Station. :rocket:
That’s great to know, and I’m glad you got it working :smiling_face_with_three_hearts:
Hello @donbusci
Thank you for sharing info :clap:
