Elements Crashing while Publishing after Images (SVG, PNG, JPG) are added
RapidWeaver Elements 3.1.3 (24707)
I’m beginning to really hate Elements and miss RapidWeaver. Every time I add an image, I have to constantly play with it in various image editors (Apple Preview, Pixelmator, etc.) to try and find a format that won’t cause Elements to crash when publishing to their hosting platform. This is getting frustrating and annoying.
Is anyone else seeing problems like this? I haven’t seen anything in the forums. I’m running macOS 27.2 on a 2022 Mac Studio M1 Ultra with 128GB RAM and a 4TB SSD with less than 1TB used.
Never had a problem with images and I use many. Elements has never crashed for me. But I’m on macOS 27.1 .
Hey @D.Stempnakowski,
Sorry to hear you’re having such a frustrating time with Elements. That’s certainly not the experience we want you to have.
You shouldn’t need to edit or convert images in other apps just to get Elements to publish successfully. Something is clearly going wrong here, and we’d really like to get to the bottom of it.
Could you let us know what image formats are causing the crashes (JPEG, PNG, WebP, etc.)? Also, does Elements crash during the publishing process, or while preparing the site for publishing?
If you have an image that consistently causes the crash, it would be really helpful if you could send it to us so we can reproduce the issue.
We take crashes seriously, and we’d much rather fix the underlying problem than have you work around it.
Thanks for bearing with us while we investigate.
Have never had Elements crash and I cannot see me going back to RW. I have multiple images but I have never had to edit them after putting them on the page other than sizing them. The one and only issue I had was images missing from a published page if they were JPEG when everything else was jpg. That was easily sorted.
Why do you need to play around with the format of the image? If they are jpg they should just work.
‘Should’ is the operative word. I am going to send my info to Dan as requested. I have a project that worked and uploaded; then I added a JPG image, and Elements started crashing when I tried to publish. I converted the JPG to PNG, and then it worked. Today, I added an SVG element and added an SVG image - crash on publish; convert to JPG; crash on publish. Remove the image; it works fine.
Hi David,
Thanks for the extra detail, that’s really helpful, and thanks for sending your info over to Dan.
A couple of quick questions:
  1. When Elements crashes, are you sending the crash report when it offers to? We haven’t received any from you yet. If not, could you send the next one?
  2. Have you used the AI Assistant in Elements, or any AI through the Elements MCP server, on this project? For example, to change site settings?
Cheers
When it has displayed the crash report, I’ve clicked Reopen. Not sure if that generates a report to you all or not.
I tried six times to publish, it reads Exporting 0/32 pages, then crashes. On the 7th try, just now, i worked through. I will still send images to Dan.
I’m not using AI.
@dan, attached are all the images that caused this project to crash during export. Is it possible the problem lies in the Project template? I’m using Studio by WeaverPixel.
Crashed again today while preparing to export.
It took three tries to export and finally publish.
Rapid Weavers Elements Crash Report.pdf (1.6 MB)
Hi David,
Thanks so much for sending the crash report and the sample images, they were really helpful. They pointed us straight to the cause, and we should have a fix in place in the next build.
Thanks for bearing with us.
Cheers
