Elements not saving? Lost 3h of work!
I worked on my website all morning. Made a “control-S” and quit.
15min later, opened my projet and discovered it was the one of last night!!! :face_with_peeking_eye: No traces of another file in the “Recent” menu, in TimeMachine or anywhere else! Did it happen to anyone else?!!
Hi @SputNic
Sorry to hear that. :cry:
Do you mean “Command + S”? control + S isn’t the default keyboard combo to save a project file.
You might want to check if you’ve got a duplicate project file on your Mac somewhere, perhaps your most current version got saved to a different project file somewhere.
Thanks for your reply, Dan!
Yup, I meant « Command-S » :roll_eyes:
No duplicate (unless it got another name and I will never find it!)
My instinct (built on this kind of experience) would go for an “iCloud automatic sync problem” (often not nice with « packages » files (DevonThink, Scrivener…). But Elements being built to be synced with iCloud, it must be something else!
I manage to re-do my work much quicker than when I did it the first time…
Now I always check the date/time of my Element file before quitting… just in case.
Regards,
Nic
