I’ve just moved from RW Classic/Stacks/Foundry3 and want to change square photos into round ones, can this be done in Elements? If yes, how? Need some help. Otherwise my only option would be to screen grab the circular ones from my existing church website. Thanks, Mike (the Newbie)
In the borders option set radius to full all 4
If you select your image in borders on inspector, set the setting to “static” change all your widths and then change radius to full that should work!
Thank you Steve, I shall give that a go…and see what happens ![]()
Yes, thank you, that worked fine, though I might never have found this through trial and error. ![]()
