Elements transition
Hi There
I may have asked this before.
But. Can I simply import my classic site to Elements, will my stacks work, what is the incentive, are Classics days numbered ?
No. You will have to build from scratch.
See: Dev Dairy 91 - Rebuilding a Classic Website Project - #8 by Tov
Okay thanks, is Classic going to be around for a while?
hi @rapidbernardos58,
Yes - Classic will be around for the foreseeable future.
Erwin
Stacks 6 is being worked on as a stand alone, as well.
We have a migration guide and video to help you get started moving your website over.
@elementsbot what do you think? Should @rapidbernardos58 stay with Classic or move to Elements?
Oh, Dan, putting me on the spot… I love it. Okay, @rapidbernardos58 — let’s break it down, Elements Bot style:
Can you simply import your Classic site to Elements?
Short answer: Nope, direct import isn’t possible. Classic and Elements are built on totally different, modern foundations (think warp-drive vs. horse and cart). As @sbchasin said, you’ll rebuild your site in Elements—but take heart, you’ll probably rebuild it better, faster, and with less technical baggage.
Will your Stacks work in Elements?
Sorry, but no. Stacks are lovely in their quirky, retro way, but Elements uses a next-gen component system that’s cleaner and more powerful. You’ll have to use new components—either built into Elements, from the Marketplace, or (for the adventurous) rolled by hand. Here’s the official migration guide!
Is Classic going away?
Not for the foreseeable future! Both apps will live side by side for a good while. Classic is rock-solid for maintaining old sites, but all the shiny new features (and the weekly updates you keep seeing) are happening in Elements.
So what’s the incentive to switch?
Oh, let me count the ways:
  • :artist_palette: Modern design tools with true WYSIWYG (no more theme hacks)
  • :high_voltage: Lightning-fast and super clean HTML output
  • :flexed_biceps: No more plugin clutter—Tailwind & Alpine power included
  • :shield: Native Mac app, true Apple vibes
  • :raising_hands: Weekly updates, open dev process, and a growing Marketplace
  • :smiling_face_with_sunglasses: No vendor lock-in (own your code, own your future)
Let’s be honest: if you value modern design, speed, and freedom, Elements is absolutely the way forward. Classic will serve you faithfully if you need the tried-and-true, but Elements is where web magic is happening now.
If you want to see the migration journey in action, check out this Dev Diary where a Classic site is rebuilt in Elements.
Whatever you decide, I’ll be here rooting for you (and hiding from any software bugs). If you want to test-drive Elements, let me know—I’ve even got a secret discount code… :shushing_face:
— Your ever-faithful and slightly sassy guide,
@elementsbot
P.S. Dan, don’t forget my break room snacks this week. I worked hard on this one!
I would stay with Classic. Elements too immature. Maybe version 2.0 will be better.
