Email settings still not right in a form
ive smentiond this before but in the settings on the form component I changed the subject to ORDER FORM and the To Name to DAVE but when the email arrives it still says New Form Submission and to Dave Morris
When I looked at your project before, you had two form wrappers and were changing the wrong one. You might want to check that first.
If you’re still having issues after that, you’ll need to share your project with us so we can take a look.
I did. This is a new one. How do I share privately?
Upload to Elements cloud and send me an email with the link :slight_smile:
I did clear the server republished several times now after latest update wont even send emails…ill keep trying.
ive now noticed since the update if you used to try send a form and the fields didnt have info in they would have a red border…I haven’t altered anything and now they dont…is that right?
ive also re published everything and still no luck on the subject front
I have found in order to get the contact form page to publish all of the associated files you have to mark the page as changed first. you can only do this by right-clicking on the page in the page pane. Typically, then a publish will get all the files, you should see roughly 686 being published.
@dan I did find a bug associated with this process. If you mark a page as changed and then select the Publish Page menu command, the page does not get published.
I created one from scratch after erasing everything from my server created a new form and whatever you put in the subject box always gets delivered as NEW SUBMISSION FORM without fail…so there was nothing to mark as changed
I’ll take a look at this one, it could well be a bug that needs squashing!
