Equal Heights Flex items Elements
I can’t get my colunms to equalize, look for some advice.
couple of things, difficult to see your settings, you may have some settings that cause this
do you need the container just place the 2 texts directly under the image, the background color for the text can then be on the flex
I assume on your layout the background is on the container? the container is set to auto and not full??? cant see your settings
You can just set a BG colour on the flex (that’s probably the easiest fix). The other way is to set the height to full on the containers in the flex. Here’s a video talking through both options :slight_smile:
Thank you Dan, I went the easy route and just put everything in the flex. I initially used the container becuase I wanted padding around the text and buttons, but I can do that per element. Thanks again for being so responsive. I’m having an issue with a clients site that’s been built with Foundry, I’ve decided to just rebuild it with elements, this is my first full build with Elements so I may be hitting the forum up with some more questions as I go, I’m kinda under the gun to get it completed quickly.
Awesome, and no problem, we’ll be here to make sure you get the client site built successfully :saluting_face:
If you need anything just holler!
