Hi, we noticed, that if we add slashes in the name of our resources, the internal web server does not start anymore. Our resources are very often exports from Sketch app and there one uses slashes to organize items.
EDIT: We use folders now instead. I’m reporting this solely for the product team to decide, what to do about it.
Thanks for the report, however, it seems to be working here
I’ve tested this by using an image with a forward slash in the name "image/photo.png", and it appears to be working as Elements converts the filename to "image_photo.png" on export.
Could you share a project where it breaks the webserver? We can take a look and see what’s happening
And yes, creating folders in the Resources area is the way to go
Thank you for checking it out. I tried to recreate the problem again and found out, that the slash in the name is only a problem, if the resource is set as the project logo.
