Errors in Realmac Software code?
Hi @differentdan and @joeworkman ,
@willwood has been generously helping me with my website. I had found two error filings after using the validator.w3.org page.
I have attached a screen grab of the coding errors and a copy of his response to me. Please can you help me out with this? Thanks so much, Debbie
Blockquote
The first error might be because you are declaring the character set twice:
This may be a theme bug, requiring Realmac Software to delete the first line. Normally RapidWeaver 8 and RapidWeaver Classic add the language and character set on your behalf, so I don’t think there is a need for the theme developer to do this. Certainly none of my themes ever had a character set hard-coded in, so I reckon this is something Realmac Software need to fix for you.
The second error is becasue you have got an empty meta tag being added to the page:
This may be because the RW page inspector description box has been left empty in favour of your SEO helper stack doing the meta description instead. This might be an issue Joe Workman and Realmac Software need to get together and discuss. But I cannot be sure where this empty tag is coming from. it is still there if I delete the SEO helper stack.
Another theme bug I found is that although you have got ‘credit RapidWeaver’ disabled, the Artful theme is still putting an advertising link in back to Realmac Software. So this is definitely something they should get updated for you. If could be viewed by search engines as spam / advertising.
Blockquote
