Expected behaviour container
is this the way Container works? happens with text etc.
Not sure what you’re trying to do here?
@dan
when I set the container layout to screen and the container sizing to less than 100% the image has a left margin/padding and goes off the screen causing scrolling, with no margin/padding to the right
it appears the % less than 100 is applied to the left of the screen
You shouldn’t be setting the content to “Screen width” and then making the container 10% smaller than the screen, that just doesn’t make sense/won’t work.
It probably looks the same in Safari, right?
yes to safari, just wanted to know it was expected
