I want some text to fade in, not slide and fade in. This setting appears to do nothing:
And this Reveal setting only works with one of four directions:
@bruce
yes only 4 directions
used Reveal to fade in text with no movement
Code see here as well, not sure which code you meant
Not sure if this is answers your question
Exactly what I needed. Thanks @upssjw
Have you tried setting the distance to 0px?
that’s what the video shows
Steve showed that and that is what I did.
ok this is just an svg in a container, the code in css classes is Tailwind but with arbitrary values (css) all in one you can add additional controls
my svg is not balanced I cropped it unequal
