whenever the homepage address is set to a subfolder of the main URL, something like:
https://fuellemann.info/test/xxx
the favicon will not be loaded and console will display a 404.
[Error] Failed to load resource: the server responded with a status of 404 () (favicon.ico, line 0)
This does not happen if the hompage address is located at:
@dan @isaiah is there a way to check if this is the case in general in these circumstances? I am sure we had this subject in some issue with ressources and stacks as well…
