Filter enabled as default
Why is the filter part of every component enabled as default?
The filter and tags in my opinion also should be placed at the bottom of the list after the borders setting.
Background, Background overlay and Borders should be placed above Transitions.
Is there a way to rearrange them my self?
This is probably just me :slight_smile:
I’ve been thinking something similar: the organization doesn’t match what I use most to least. Also: we now have so many panels in some components that it seems like grouping needs to happen, too. For instance, are not Transitions, Effects, and Transforms related? As are Background, Background Overlay, and I’d add Borders. It seems to me that there are ways to eventually group these (but Dan, not in 1.0!).
Yes, I think filtering should be off by default - we’ll get that fixed!
For now, grouping is based on how Tailwind does things, however I think you’re right, we probably do need to re-organise it a little bit…
I’ve updated the Filter to be disabled by default - this will be included in the next beta :slight_smile:
