Filter tags broken
tested the filter tags and they dissappeared compared to last time. I filter over a custom ID not over the parent. And nothing shows up.
I’ve replicated the issue here, we’ll get it fixed up and included in the next build!
Hi @ben,
Was just building a demo. You beat me to it :smiley:
btw … looks like the Search has the same issue. I tried that one too.
yes, there’s an issue when using the custom group - I’ve fixed it for all components :slight_smile:
Has this fix been released yet ?
Should be fixed in the build you’re using, are you still having the same issue?
Hi @dan
the version is still 0.6.5. Are you releasing that fix soon? Otherwise I do not get the comment. How can it be fixed in the build that I am using, if I am still using the same version :thinking:
Anyway as soon as those tags are fixed I will publish our first page :hugs:
Take care.
I am using 0.6.5 (23321) and yes it, and the search field, don’t work :frowning:
Okay, sorry guys, my bad. Turns out we didn’t actually ship this fix yet :face_with_peeking_eye:
It will be included in Build 0.6.6, due by Tuesday!
