Flex Demonstrator + Grid
ok tailwind and grid demonstrator
https://sjwjaw.co.uk
Test here
Link no longer valid
This was great; thanks!
forgot to unhide the menu - link should have menu so grid now there
grid works on lines not the squares so the odd numbering one more than you think
ok upfront I never wrote these I used AI, no way could I invest the time to do this, I normally write my own stuff when it is quick and easy, not too much effort
project here for free etc leave until tomorrow morning no use to me I understand grid and flex enough not to use these
elementsapp://downloadDocument/dsPCrOn5M2A1
The updated project below generates code that will work in Elements custom component, replicates what you create on the demonstrator
Download no longer available
ignore that one if you would like to copy the code :joy: :joy: :joy: :joy:
Needs desktop really mobile more difficult to scroll up and down
delete all tomorrow morning
updated test site
project - elementsapp://downloadDocument/YAgDnu3NQb48
https://cleanshot.com/share/xxBGH16hZKYtWDFX0N4n
updated with better overlapping select - elementsapp://downloadDocument/xTGvupe4KxWD
All links and downloads no longer available
If you are in this thread looking for the project/playground after the above links are deleted/don’t work, I’ve hosted it and will keep it up.
I’m still trying to wrap my mind around the flex/grid components and this is very helpful to me!
container as flex
simulator
Elements
its not just about boxes it a positioning component, switch row to col etc at different screen sizes or use wrap depends on your layout, items do not need to be in flex but single flexbox provides greater control
showing a friend just how to use flex no grid for a page, got this far, bit more to show yet, simple no container as flex, next step after this just grid, delete end of day both demos and website
try to always check it works online
project - elementsapp://downloadDocument/Yza7xYlw6lLi
adjusted top images and more realistic staples (stretch there :joy:), website updated
OCD on staples - elementsapp://downloadDocument/JzSvikOX2iXH
Download links no longer available
I think the staples are cool (Elements), had to add a little tailwind because divider is missing controls
Colour and text also missing controls
