Hi everyone, Flexer is the next project to receive a Design Guide for the Elements AI assistant, after Lander, Cordial and Lumi. Before the technical part, a few words on why Flexer is different, because the guide is built on that difference.
What the guide does
The guide lives in the project memory and teaches the assistant all of the above: the models of the Starter page, the header and layout options, the colors with tested contrast in light and dark mode, the fonts, the Flexer Script classes. It also tells the assistant what not to “fix”, like the sidebar columns. In our tests the assistant created a new page from the Starter, added it to both menus, explained the sidebar behavior correctly and ran a style check that found real issues on its own.
How to get it
- New project: update Flexer from the Elements Store and start from it. The guide is already inside.
- Site already started: open the updated Flexerand follow the block at the top of the home page.
- Updates: just ask your assistant “check Flexer guide updates”.
As always, the AI assistant is not included in Elements or in Flexer: you connect your own (Elements > Settings > AI). If you bought Flexer on the Multithemes Store, you have already received an email with everything you need.
thanks!
