Float and practice
working through the tailwind classes I have not used, in this case float, don’t think I have ever used float before, so still a few more float bits still to figure out and add some more controls, video of progress and html component to date
elementsapp://downloadDocument/u25uLtIqTys0
That’s a great use of Custom Components and Tailwind CSS, love it :smiling_face_with_three_hearts:
Dan thanks still not finished, is this behaviour expected, you see as I select before the letter correct colour, once I selected it is the colour of the previous letter
Still have float-start float-end float-none to add plus a few more styling bits
Didn’t need p tag as Elements has text and typography
Could remove the float width and just let Elements control the width etc eg container flex perhaps
Yeah, it’s kinda the way it works… when you move the cursor back it selects the last block of colour. I know it feels strange, but it does work.
As long as you can set the colours you need on text, I think we’re good!
it works no problem, all good
@dan updated Elements, copied custom component, image does not show in Elements but does in Safari
also not sure if this is possible - but dragging a page from one project into another crashes Elements
Thanks for the feedback on both of those issues, I’ve ticketed them to be fixed. Stay tuned!
