Folders in Template Panel
I noticed in the template panel that there is a slight problem. If you create an EMPTY folder you cannot drag it to a different position unless you first put something inside of it.
This seems like it might be a bug!
This is in my custom ElementsPak that this happens. It is not a problem in the resources panel when creating an empty folder in my pak. Only seems to happen in the Templates panel in my pak.
Hi @handshaper,
Thanks for reporting this, I’ve been able to reproduce it and will get a fix into the next release :+1:
