Over the past few days, I have done everything I can to solve the following problem:
When I use the form component and use it under my local Servbay installation, the connection to my Zapier Zap works smoothly.
However, it does not work on my Ions(1und1) web space.
So I set up an AWS Lightsail instance and installed an Apache server on the Ubuntu (22.4) instance and configured it so that I have full control. I checked everything. The website works smoothly. Only the contact form always reports a submission error.
I compared the modules on the Apache server with the Apache server from Servbay and adjusted them. Still no success.
Now I’m at a loss. Maybe someone can give me a tip. The error message in the developer console is always the same 404. Is it a read/write permission issue? Or do I need a special Apache server config? Any suggestions are welcome. My internal DevOps team is already desperate. They pride themselves on solving every problem, and I’m scratching their self-confidence.
Unfortunately, I am not receiving a log file in the directory /var/www/otaliolab.com/html/rw/elements/com.realmac.corepack/api
The directory is created and filled on the Servbay installation /logs. Unfortunately, this is not the case on my AWS - Lightsail instance. I suspect it is a permissions issue… but I have no idea what that could be. I can send you the log file from my local Servbay installation for documentation purposes. If that is helpful.
