I’ve read other discussions regarding contact form problems but those discussions have been closed. Now apparently there was a bug. Is this fixed? Because I absolutely cannot get my form to work. I have spoken to webcentral.au who told me the settings that I showed them with a screenshot are correct but still no success. Any clues from anyone who informed on this topic would be much appreciated.
have you checked with your host they have the right PHP version
using PHP v 8.4
The also did check on ElementsAPI which they say is functioning correctly.
Cheers.
OK.. I added the ‘error’ component and it does appear when I try to use.. so there is an ‘error’..now how do I work out what this might be. Any ideas?
have you added the success as well?
need both
yes I have both ‘success’ and ‘error.’ I have managed to get output by using the webhook system via make.com… but it’s just another layer of complexity… I’d still like to do it without the webhook thing..
