Form Radio Node - styling
I was investigating whether the Form Radio node could replace my use of Select node.
However, the styling seems a bit problematic (or maybe it’s a user problem? :wink: ).
For unchecked, I see this:
For checked, I see this:
The border option has disappeared for checked.
Also, there doesn’t seem a way to style the dot in the selected check box. It is always white. As a minimum I would expect it to be the colour of the checked label text. Ideally it would also be nice to specify something different to a dot, like a tick for example.
Of course, I could be missing something which is more than likely. :slight_smile:
Good catch. I’m just chatting to @ben about this and will get back to you shortly…
this one has been fixed and will be included in the next update :slight_smile:
