Form setting not changing
ive changed the ’ new form submission’ in the settings to ‘order form’ but the emails keep having the ‘new form submission’ title…ive republished all files but it wont change also I change the to name setting but that wont change either
Can you try re-publishing all files again to see if that helps?
Failing that you’ll need to send us your project to take a look at…
ive sent email cos not sure how to share privately as dont want everyone to see password for email accounts? in form settings
Found the root of the issue. You have two form components. Remove one and ensure your details are correct on the remaining form component.
cheers … ive been experimenting and had a weird thing pop up,if I changed the name to whatever and checked it in outlook it picked it up but not apple mail hahaha
I think I sent wrong website. I have another trial on and there is only one form!!!
and I cant get it to upload to my elements cloud
removed the 2nd form…didnt do anything
update
because I copied your form from wherever I thought it be something hanging on from your form so I did one from scratch …same thing can change the subject in the form but nothing changes on received email,could add subject input I guess but the email received will always say ‘new form submission’
