Forms how do I get it to work
how do you set a form so it sends out the email to you I have watched the video loads and I just don’t get it on the old classic I put a stack in and it worked very well for what I wanted old site
simonandrew.co.uk if some one can have a look but on elements I have to put so much more info in and I’m not sure if its right I have my new site ready I think, but need to make sure the mail works. can anyone point me in the right direction please. (been pulling my hair out for weeks now)
thank you.
simon
Hi @simon28
We’d probably need to see a screenshot of your form settings (with the password redacted) in order to help.
that would help wouldn’t it thank you.
Hi @simon28
Your From Address field is wrong. It should probably be driving@simonandrew.co.uk, same as your To Address field.
Try updating that and republishing to see if it works.
@differentdan
Thank you for your help I have sorted it now . I had to update to php8.4 on my host and then delete a public-html file and then it worked then changed the suggested address so all cool thank you.
