FormSnap 4 does not work
I have switched from FormSnap 3 to 4. However, no FormSnap is displayed on my pages. Nothing, no input fields, everything is blank.
There are no problems with FormSnap 3.
I have no idea what I might be doing wrong.
The PHP version is PHP 8.2. or PHP 8.3.
No matter if Foundry or any other theme, nothing is displayed on the published page. Everything is fine in the preview.
Any ideas what the problem could be?
Many thanks and best regards!
Hi @Kunstmaler, any URL to check? I use Formsnap 4 with Foundry 3, blank theme from Will Woodgate and Source project, no problem. My webserver is on php 8.2
Thank you @Bruno,
I only have one test page that I don’t want to publish.
I’ll try another website and get back to you with a URL.
Ouch, now I’ve uploaded the whole thing to my private website (Foundry). And it works!
The only difference to my previous attempts: I used RW Classic. The previous attempts were all with RW8.
I will try again with RW8 and Foundry3.
I’ll let you know then.
I don’t think it’s fair!
Now it also works under RW8.
But I haven’t changed anything, at least not consciously.
Made another attempt with RW Classic. Worked perfectly.
Then took the page with which I had no success earlier (under RW8). Now it works. That’s good, but also kind of mean.
Gained zero experience, don’t know why it works now. 3 hours of life just disappeared like that …
Now I just have to get it working with the customer website. But not today …
Thanks to @Bruno for the help offered :slight_smile:
Don’t be sad about so little, I struggled half the day to redo a psychological evaluation of a patient that I thought was lost because of a backup problem or something. While printing my report, I was just brought the said evaluation that my secretary had taken out to bind it. You see the Karmah I will end up believing it :rofl:
:smiley:
I couldn’t wait and tested the customer website. Everything worked there too … and all without a secretary.
Well, I’ll take it as a good sign.
