I have had to wipe my hard drive and reinstalled Ventura and backed up by Time Machine but since then stars have been missing I have been through the Library deleting everything I could find related to rw and reinstalled classic stacks and foundation 6 which has installed now but when previewed foundation 6 is missing.. All the boxes are ticked in the preference pane and show the stacks are present
Hi @graham-sm1th,
Does the Foundation 6 theme show up in the theme browser?
If not - it’s not correctly installed. You could try reinstalling it.
If it does show up, make sure it’s selected as the them of the project you’re working on. Foundation 6 only works with the included theme.
Erwin
Many thanks Erwin,
Joe Workman got in touch via Zoom and got it sorted in 5 minutes. My files were all over the place as my hard drive had got corrupted. Couldn’t believe it when the Big Chief got in touch, but all Done thank you for your input.
Graham
