Foundation in Elements?
Hi All
I’m just about to embark on a new project in RW Classic - I’ve not looked at elements just yet.
Before I dive in, and this has probably been asked before, so I apologise in advance but… will Workmans Foundation work in Elements? I really don’t want to dive in and find out a few months down the line, I’ve got to switch frameworks.
Many thanks in advance
Mark
No, Foundation is made to work with Stacks, and cant function in Element.
And why would you want that? :wink:
Elements runs on the Tailwind CSS Library. The library is smart in that it only publishes what it needs and it has a lot of logic built into the core. That said, Foundation is simply another competing CSS Library that has its own way of doing things. Depending on your needs, the potential with Elements once fully completed will be not needing to know or think about the CSS at all.
Hope this helps!
If you’re looking at emerging Framework trends, the State of CSS 2024 is a good place to start!
K - Thanks for the input
So its fair to say that whichever framework I use currently, when I move to elements, its going to need replacing?
Apologies, I was under the impression that existing stacks etc would work with the new boy in town ( which I’ve yet to play with )
Mark
