Foundry 3 - Help!
Hello, I am an avid Foundry user, and have been for some while. I have a number of client projects built on Foundry 2 and 3 and I am maintaining these.
The problem - after getting a new Mac, the foundry 3 .stack file was not backed up with my other stacks file so I am left with sites that are built on foundry 3, but no means to edit them!
Elixir Graphics is gone, and there is no way I can see to download old purchases. Does anyone have a solution (other than rebuilding everything from scratch!!!)???
Sure, here’s a download link — it’s only valid for 3 days as it’s on WeTransfer.
Perhaps now might also be a good time to start exploring Elements for future projects!
Thank you so much, you are a life saver!
This has certainly put my reliance on Foundry into perspective, so will not use Foundry for new projects anymore. Time to review what I use in the future…
Definitely staying with Rapidweaver, so I will take a look at Elements and have a play around!
Thanks, again!
@rossnet Hi, as I have been using Foundry exclusively for my clients and now switched to Elements, I can be of help if needed. And if you need to port complete sites, we can do so as a paid service at https://classic-to-elements.com.
Jan
Thanks, Jan, appreciate the offer. I will have a play with Elements independently to begin with, but will give you a shout if I need support with transferring existing sites over.
How does Elements compare to Foundry+Alloy? Does it have alternatives to most of the stacks and functionality?
Yes, it has pretty much everything you need built-in, it’s also a true WYSIWYG editor that once you get used too, there’s no going back :smiling_face:
Check out the getting started video for a quick look at how things work in Elements…
You can also download a free trial to get comfortable with how it all works before you purchase, there’s no time-limit to the trial so you can take your time :slight_smile:
Thanks, Dan! I’ll take a look.
I switched to Source, which has worked well for me. Although the amazing person he is, Stuart is still providing support, but Source is on a slow sunset path. So, eventually, I will be moving to another RW platform. How are you finding Elements? I am looking for objective pluses and minuses.
bob
