GB24 Fin System
:desktop_computer: GB24 Fin System
:hammer_and_wrench: Built with Elements by Robin Mair
:link: Visit the site: GB24 Fin System
:pencil: Builders Notes (optional):
This is another one of my sites that I ported from Classic/Foundry/Stacks to Elements. It is another one of our businesses that manufacturers fin boxes that are installed into surfboards, into which fins are attached. This is a product that I designed and is in its fourth iteration. So glad I can now maintain these sites in Elements. Of course, it did get reworked when it was moved over and is still a work in progress. This site also has e-commerce support using Cartloom and a custom component. The primary missing piece in all of the sites I have done is some sort of GDPR support.
have a look here…can create free ones
https://www.freeprivacypolicy.com
Aloha David,
Yes, I have found a free privacy policy generator but what I’m missing is a cookie consent system to comply with the requirements of various countries. I had an excellent Stacks based one in Classic, but the developer decided not to port it to Elements when RW abandoned the idea of supporting the conversion of stacks to Elements.
I have a number of different third party options I have been looking at that I have used in the past but they all cost money. I’m holding out for some minimal support built into Elements.
I got a cookie thing from there as well
Yes, I just found it and have been testing it out. Seems to work fine but there is no easy way to customize the text it displays as some of the wording does not apply to me.
Thanks for pointing me in their direction.
I doubt many people read these things haha like user license agreements or instruction manuals
I agree
The site has just been updated with a completely new mechanism for accessing the INSTALL data for the fin system. Phew, glad that is out of the way. Lots of other tweaks and improvements.
thanks. ill take a look
Very impressive website.
Outstanding site Robin, great job!
Thank you.
