Global text element issue
Issue with Global text element:
  1. Insert it into a page.
  2. Do not activate Global Override.
  3. Edit the default text by deleting it.
  4. Any other use of the Global Text element does not have the default text,
If I exit the Global text element and try to double-click inside the element, it is not possible to do so.
Add another instance of the Global text element (which now has no default text); it is not possible to do so.
If the text is deleted, it is not possible to undelete the deletion.
The only option is to create a new Global text element. Any previously created elements with the Global text element are no longer linked to the new one.
Even after unlinking the text element from Global, it is still not possible to enter text.
Is this correct or am I overlooking something?
Please see the attached video.
The issue is already known and is on the to-do list for fixes.
