I want to know if a project made in V5 will open up in V.7 or V8.
And which one is preferred. I’m a newbie that needs do his own stuff now…
I’ve opened v5.4.1 RW files in both v7 and v8. I would make a copy of the v5 file before opening it in a new version, in case you need to go back to it.
Ok Great, that is good to know
7 or 8 should I update to ?
Definitely version 8. No reason to still use the old version 7 in my opinion…
Ok there is price difference on the App Store and I was wondering if it was worth it or not…
Thanks for the reply
@slybass3000 Yes, there’s a price-difference. But you’re about to invest money. Now. My advice would be to invest in the future, and not in the past. And RW8 is the future.
Thank you all for your input. Greatly appreciated.
Here I come V8
