Grid Item Reordering
Hi there,
Is it currently possible to reorder grid items in a layout?
For example, I have a simple two-column grid: the first item contains a header and some text, and the second item contains an image.
On mobile, I’d like the image to appear first—above the header and text—instead of second. Is there a way to do this?
Thanks!
@ajenks assume you mean like this
Hi @ajenks
As Steve showed in his video, you can absolutely do this. I’ve recorded a quick video to explain how to achieve this, have a watch and let me know if you need any more help! :slight_smile:
Advanced grid provides so many options to control layout of grid almost limitless :joy::joy::joy::joy:
Thanks @ben for taking the time to run through this in a video. That helped alot, I got my layout working the way I want.
Thanks again,
Arlen
Elevating on this. I´m trying to do custom ordering. What am I doing wrong? I want it to be overwritten at medium breakpoint. On medium I want the second picture to be to the right. I have set all container/griditems to a order value but they don´t change order.
assume like this, not sure how you wanted the text order
Yes. How did you set up the ordering?
when using grid I only use advanced grid its a bit more, would need a video , I mixed advanced into your project, it will need a video to show
if you set up grids in the grid it is possibly easier to manager order
Thank you for videos!
That is a lot of grids. I would prefer the custom ordering to work.
@ben is this possible?
I never use auto grids if possible so may be possible, prefer knowing where the grids are aligned takes a bit more work
