Grid layout not setting up when viewed in Preview
I am using NORTH ELEVEN Project and have used the project to plug in my images and texts. I can’t figure out what element is not configured correctly. Seems fine during construction:
But not when previewed:
What should I look for that may be creating the problem?
I am new to Elements. I can’t reason out what components would create this disparity between views. Any suggestions?
I’m wondering if it’s an issue with the image format :thinking:
Can you share the project via Elements Cloud? We can then take a look at the project and fix the issue for you.
Thank you Dan. Before I have you take the time to look over the project, I will review the images ( sizes, dpi, and format) and see if that helps. If that’s the issue (which is simple enough to fix) then I’m good to go and I will respond thankfully on this chain. Otherwise, I will take you up on your offer to review the set up via the cloud. Thank you again for responding.
I was mainly guessing that perhaps the extension was wrong on the files, and the browser couldn’t render them. Strange they appear in the Editor, but not in the Browser :thinking:
If you share the project we’ll be able to get to the bottom of it :slight_smile:
I have uploaded the project to the cloud. Since you aren’t accepting messages, where should I send the link?
if you put @dan here he will come back to you.
here is the Project
quick fix
THANK YOU. I understand now.
