šŸ‘» Halloween promo 30%Off Elements projects and more
Hy RW folks
:jack_o_lantern:
Halloween promotion is here. :ghost:
All products are 30% off, a great opportunity to get the most advanced and complete kit for creating websites with Elements today.
All projects offer several components, All the key elements you need to build a complete, production-ready site.
preview
preview
preview
preview
preview
And also RW classic and stacks, included the Motion Design bundle.
limited time offer, 2 days! :magnifying_glass_tilted_right: Multithemes Store
Thanks!
Questions :slight_smile: had ascent in my cart 2x
Do the custom components work in all projects?
Are they just loaded with ascent?
Are you going to have CMS templates?
Ascent title font - Would like a different font - able to change?
Very nice design and job!
I have 6-7 RWC themes :slight_smile:
Hi Michael and thanks for you question.
The philosophy behind my project development is the same one I followed when working on RW Classic themes: the goal is not simply to provide a template, but a cohesive and complete product that includes all the necessary elements to build a real website.
Without these components, some essential elements would be missing, but this doesn’t apply only to the components themselves. The projects also include a ready-made Legal page and a Privacy Policy page, a popup to inform users about the site’s policy, and a footer with all pre-configured elements ready to be customized. The philosophy applies to the entire project, the components are just one part of it.
all_big
The components included in my projects are designed to deliver a result as close as possible to my previous quality standard. These components should therefore be considered as part of the overall project, but they can also be used in any other project. You can simply copy a component from the original project and paste it into a new one, it will work independently.
core_sliders_icon_component
For the ā€œCOREā€ component, however, I used a smart technique to extend the functionality of the standard Elements components through a simple CSS class. Each project includes a specific CORE component that contains the code required to modify the standard elements. Nevertheless, the CORE component can also be applied to other projects, though in that case, it’s advisable to copy the related standard elements that use that class as well.
in all cases with Core Component you can also change the class from the component panel if you use it in another project.
The demo projects will be updated (free) to include all the major new features of Elements, but only once those features are stable and finalized. This approach also helps avoid creating development issues for the RMS team, who are working hard, we just need to give them a little more time :slight_smile:
As I mentioned above, the philosophy is to offer a complete product, so the main font families are always included in the project to ensure it can be used offline 100% GDPR. The DMG packages also include additional fonts that you can replace if you wish. In any case, yes you’re free to change the fonts as you prefer, or use the ones provided by Elements or Google.
Thank you very much my recent work on Elements exists only thanks to the experience and foundation I built while working on RW Classic. :heart:
Thank you for the detailed response - very informative…
I like that the components can be used in other projects
Will the components stick? Or stay on the default?
I don’t know if I’m describing this well…
There’s a spot in elements: footer, menu, buttons etc
Will these new components / project sections get added there?
Make sense? Hopefully :crossed_fingers:
Take a look; all the components are in the project (blue) and you can place them wherever you want. The CORE (purple) in the project controls the menu and header through the classes of #ID. Both the menu and the header are standard elements, enhanced by the script :slight_smile:
In all my projects, the element names are logical,
and you can quickly navigate to everything, just typing edit, image, code, etc. I’ve made every effort to explain to the user what to edit and how the project is done, understanding the different elements by name..
