Hamburger Menu on Simple Menu
It would be good if Simple Menu would turn into Hamburger Menu on small devices.
Could use the Standard Menu if you need a hamburger on smaller devices?
Yes or sticky, but why not Simple too? Or at least an option to use Hamburger ..
Because the “Simple Menu” Template actually uses the “Top Pages” Component, and that’s just a way to list out pages. The other Menu Templates use the full-blown “Menu” Component that supports the hamburger.
Remember, everything is configurable in Elements, and there are an infinite number of ways to achieve what you want. For example, you could hide the “Top Pages” at the mobile breakpoint and show a dropdown menu instead… that’s just one idea :slight_smile:
