Happy :) My Biggest Site is Live :) With Side Menu and Icons
Took me a little longer, had to do some adjustments… Small Top header for Mobile and Full size screens
84 Pages - Big for me :slight_smile:
DONE (for today…)
Congratulations on the launch! :clinking_glasses:
Great job. Congratulations! What did you use for the newsletter sign up?
Suggestion, as you scroll down the menu disappears so it doesnt matter whether it’s vertical or not, you can not see it. Why don’t you fix it to side and also you can narrow the menu field so that your text is wider and it means less scrolling to read it. Please accept my comments as constructive as I can see you have put an enormous amount of effort to get this far. Well done!
Search the forum for slide in code… if you can’t find it.. I’ll post it again.. html snippet…
Thank you for the feedback - do you mean like a sticky left menu? I don’t think you can do that yet…
I did make it wide 96…
If I make it smaller the line text ‘doubles’ too much…
my mistake. I was not referring to the slide in code. I meant what email subscription service did you use. Currently there is not a built in version for Elements.
@dan can you freeze the vertical menu so it stays visible as you scroll down?
I don’t have many - so far - maybe a hundred….
Was just going to use apple mail until it gets too big..
If you know of any - let me know :slight_smile:
A long time ago used mail chimp - it was ok… not great though…
@dan there is too much to try now, this is really cool
