Has anyone managed to get an RSS feed running?
“To enable an RSS Feed for your collection, open the RSS and Sitemap settings and switch on the RSS toggle. This activates a dynamic feed for the collection, allowing users and apps to subscribe to updates without any extra setup on your server. It’s worth noting that the CMS doesn’t generate a physical file. The feed is built dynamically whenever it’s requested, so you won’t see any RSS files on your server.”
But how do you subscribe to it / access it ?
Many thanks, Jol
Paste the url of the webpage with the feed on into your RSS reader and it should auto-discover it.
We also added a new feature that allows you to add a link to the RSS feed in the Collection Before or After area.
Here’s the URL of the page with the feed - I can’t anything to register in various RSS readers
I‘m sure I’m doing something daft - but what ? : P
I think we have a bug in the RSS that is stopping it from being discoverable / generated correctly.
I’ll see if I can get this fixed quickly before the next release of Elements — stay tuned, I’ll keep you updated.
Thank you Ben !!
Just a quick update: I’ve added support for generating physical XML files for both RSS feeds and sitemaps.
You can now link directly to these files, and they’re generated automatically for you.
The URLs are exposed on the collection object and can be output using {{ collection.rssURL }} and {{ collection.sitemapURL }}.
If you need to force a rebuild of the xml files, you can append ?regenerate_rss=1 and/or ?regenerate_sitemap=1 to the URL of the page where the Collection is used.
The settings look like this:
This update will be included in the next Elements update.
Good man Ben !!
FYI: I have added these details to the Collections Page in the Docs for future reference.
Whan I add sitemap-blog.xml to my google search console>sitemaps page … it says one error : it’s an html page … which it’s clearly not ?
Not sure if this helps (from Validate XML Sitemap - XML Sitemaps Generator)
The page you should be pointing to is: https://www.peteryates.co.uk/sitemap.xml.
No (I think) - that’s the website’s overall sitemap.
We’re talking about the sitemap for the blog … ie: sitemap-blog.xml
That’s my understanding anyway :
Jol
@ben I have noticed that there is a long lag between the files showing up on the server when you change their names. I guess I should have used the method of forcing an update. Which I eventually did, and that caused them to be updated.
The other thing I have noticed is that if I add a new post to the blog, the only way I can get it to show up is if I force an update. I would have thought there would be a more immediate update.
Is there a way of setting new posts to update immediately?
Looking at the blog sitemap, I see some code that deals with the change frequency, which seems to be set to “weekly”. Can this be changed?
It might be nice to have some toggles in the properties to force the updates.
I would like to bring up the topic of the RSS feed in Elements again.
After the latest updates, the feeds are now being correctly read by RSS directories again.
However, I’ve noticed that the header image is not being passed to the RSS feed .
So my question to you, @ben:
What does the Markdown frontmatter need to look like in order for the image to be included in the RSS feed output? Or is this currently not supported?
The same question applies to tags and categories.
A short clarification would be appreciated.
None of those fields are currently supported in the RSS generation. I will add it as a feature request for us to investigate though :slight_smile:
Thanks for the feedback — good to know! I’ll look forward to a future update.
