Having text issues
editing site and have a text box
set to a certain size as I increase size text just spreads out
Highlight text and pop up on right at top allows you to adjust size and colour. Also the section above weight/spacing etc may help?
if I do same thing on the title works ok but not on this blue text so why is it different
here are two more 1 is text in mobile set to lg 2nd is wide override to 4xl…both the same size!!!
After looking at your project again I can see you have some inline styles set on your text that are overriding the component settings. Here’s how to fix it:
I will have to look at that. I might have been altering things to get it to work. but if you look at my site again when you sent video you were dragging the side, I am just clicking the icons and the override size is not showing in what im working in. ie at the moment I cant set the mobile to 2xl and the small to 3xl. and if I click override to 3xl the mobile one goes to 3xl too
it looks to me like the icons for the sizes are a gnats cock out to the dragging..as I dare out just a smidge bang it jumps to the override size
this video is set to NEVER auto play but hey ho it just plays but shows the problem
Strange, I thought we’d fixed this bug already.
The issue your seeing when clicking the responsive buttons is due to you having the scrollbar visible all the time (I’m guessing you’re using a non-Apple mouse).
For the time being you can manually resize the view by dragging the edge of the editor.
This bug will not affect your published site, it’s just an anomally in the editor.
We’ll look at re-fixing this for a future build.
is it that thing in settings where you turn the scroll bar off and wow how you know im using a Logitech mouse hahaha
yes bingo back to normal hahaha after all that hahahaha
thanks for the help
