I was using 4.4.2. I purchased 6. I downloaded 5.4 Whenever I try to open 6 I get the following message…
"Your project is configured to use the a commenting service, which is no longer operating. To re-enable comments on your blog, please set up Disqus commenting within your project.
Blog comments will be turned off for this project, and some pages may need to be re-published."
I went into the project in 5 and turned off disqus…it didn’t work.
