this is mine
Thanks but I have tried as I said what @pegasus said try i.e. https://dontbeaclot.co.uk/dashboard and https://dontbeaclot.co.uk/dashbord/#/login etc etc in multiple formats and it still gives me an “error not found” message
see reply above to tribune.
pls upload your project to the elements cloud and share the link.
otherwise i don’t think so that we can help you.
just uploaded again this time setup and copied address
do you
have a screenshot of your server directory structure, the name of the page
As I mentioned earlier from the below pic you posted, it doesn’t appear that the project was published to your server:
I am happy to do this s I would normally do, but I won’t put password - as normal so how’s it going to help sort the resetting of Online Editor? TIA
If you share the project, no passwords should normally be included. Alternatively, just create a copy of the project, remove the password, and then upload that version instead.
As for resetting things, Ben already posted some instructions about that somewhere here in the forum. In my personal opinion — and probably the fastest approach — it’s best to completely delete the entire hosting path where your website is uploaded via FTP and then do a clean re-publish of the whole project.
But honestly, the best thing would still be to upload the project. We simply don’t have enough information about how your setup in Elements is configured. Otherwise, we’re probably not going to get much further.
So here’s project alls it is is the microblog project with one page added and Dashboard page added nothing else as its only a play. TIA. PROJECT REMOVED
works for me, returns to login screen
OK guys lesson learnt my added dashboard or whatever stupid spelling I had - had a HTML index file and not a php. So THANKS to everyone for all their help and TIME which I am indebted to you all on such a hot day in UK. We now have a working site and a testing base.
This was all done with the help of the indomitable @differentdan yet again.
Also to note I have set this up in testing domain to learn and play with different ideas but currently if I deactivate a licence and move it to a new/final domain I will lose all my “play” work. Dan is looking into this to see whether a folder could be copied across but currently it does not look like this is possible. So if your buying a licence please note it only works on one domain and if you deactivate to move it currently you lose that work but WATCH this space. Once again THANKS for all your help!
