Help for a newbie
Hi Guys, I am a real Element Newbie. I have just transferred/imported my Classic website (that I made for my church). All the images, text and structure was imported. It created all the pages and tried to import the Foundry3 sticky Navbar. This didn’t quite work. So I have tried to make a new sticky menu bar using one of the templates. However, it has not populated with the pages that are already there. Any help would be greatly appreciated. Thanks
Hi Mike. Welcome to the forum! It could be easier to help you if you illustrated your problems using some screenshots. Is that possible?
Best regards,
Kjell Are
Make your sticky into a global by right clicking on it, then add the global to every page. If you make any changes to a global it will change on every page.
Thanks Paul, I was aiming to get it all set-up and then save it as a Global. Because I am an amateur user and have only the Basic version, I that has only 2 Globals, but the sticky menu is the only thing that appears on every page.
Thank you Kjell, I will see if I have a a version of the ‘mangled Navbar’…but have an idea I may have deleted it with the idea of replacing it with the native Elements one that I had tried before I knew about the porting of Classic/Stacks data. When originally attempted, when I added the next page after the home page, it was automatically added to the menu bar. Now I have added a new Sticky menu, it has nothing in it apart from the Home page, yet there are at least 10 parent pages with child pages also.
