Help from Bens Custom Component video
@ben I have the following text code
<h2 class="text-4xl font-bold">The First slide</h2>
Scroll Down for next slide
I want to try to add the equivalent line in your video to make text dynamic:
@text (“heading”, default: "Start using Element”) so that “THE FIRST SLIDE” Above in text becomes dynamic.
I have tried adding the @text code so I can change it but get an error. Can you please tell me where I add the coed and what I delete to make it work please and THANKS!
Okay, so this code:
Should look like this:
<h2 class="text-4xl font-bold">@text("heading", default: "Hello World!")</h2>
The text should then be editable. Let me know how you get on :slight_smile:
PERFECT ALL DONE AMAZING what you can do when you know how! THANKS ONCE AGIN YOU LITTLE STAR!!
